Tm1 REST api - filter all subset except one dynamic subset
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 »
Hello everyone,
Is it possible to filter all the subsets from dimension except one subet.
DIM
- subset1
- subset2
- excludesubset_username #It a dynamic subset, Username will be created dynamically.
http://host:8001/api/v1/Dimensions('DIMName')/Hierarchies('DIMname')/Subsets?$filter=Name ne 'excludeSubset__User1'
above wil exclude subset when I give with full subset name.
but i want something like,
http://host:8001/api/v1/Dimensions('DIMName')/Hierarchies('DIMname')/Subsets?$filter=Name ne 'excludeSubset__*'
because username will be appended dynamically.
Kindly post ur suggestion.
Version: PAL 2.0.9.18
Re: Tm1 REST api - filter all subset except one dynamic subset
There is a filter with 'Starts with' option that you can use, to exclude the subsets that start with ...
IBM Champion 2024
kavitha2002
OLAP Product: tm1
Excel Version: 14
Thanks for your reply..
Ya I too agree startswith() works, but the scenario is I have to exclude one subset and retrieve all other subset in dimension uisng rest api.
My exceptation: Return all subsets except the one startswith("exclude_")
macsir
Version: PAL 2.0.9
Post by macsir »
you could put "not" in front of startswith function or use contains function instead. Looks like $search has not been implemented in TM1 rest api now.
kavitha2002
OLAP Product: tm1
Excel Version: 14
It worked well. Thanks a lot. :)
