Aggregations in Rows and Columns do not work
Posted: Wed Sep 05, 2018 7:03 am
we came accross a interesting issue on TM1 Production environment after creating view for one particular cube. After these modelling changes all of the views of this cube do not aggregate consolidations on rows and columns, while in the context consolidations work fine.
This behaviour appears dynamically, so swapping dimensions results in not-working consolidations of the dimensions on rows and columns that are shown at the time.
This issue happens only in TM1 Architect and TM1 Contributor. In PAW, TM1 Web and Porformance Modeler everything works just fine.
After showing aggregations in any of the working clients, TM1 Architect and Contributor shows the consolidations only for those particular cells.
We have tried restarting Web server without any progress. The only thing that works is restarting the instance, but the issue appears again after cca 3 hours of no activity on the server...
We have also tried to replace the data folder and to recreate the TM1 Application the cube is used in - again no progress.
When moving the data folder into another instance, everything works fine and no problem appears.
Do you have any suggestions about what might be causing this problem or how to resolve it?
