Tm1 Rest api: get number of levels in Dimension
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 »
Hi Everyone,
How to get to know the number of levels in Dimension and filter the dimension elements using Level using Tm1 REST api?
Is there any option to do??
Version: PAL 2.0.9.18
Re: Tm1 Rest api: get number of levels in Dimension
For instance:
{{protocol}}://{{serverName}}:{{httpPortNumber}}/api/v1/Dimensions('TEST_DIM')/Hierarchies?$select=Name&$expand=Levels/$count
IBM Champion 2024
kavitha2002
OLAP Product: tm1
Excel Version: 14
Super Wim Gielis.. Thanks for your immediate response.
Is there a way to filter the Dimension elements based on the level. For example,
{TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 1)} in mdx do we have similar in RESTapi?
kavitha2002
OLAP Product: tm1
Excel Version: 14
I have found the solution to filter the dimension elements by level, hope the below Tm1 REST api query may help someone.
http://host:8001/api/v1/Dimensions('DimName')/Hierarchies?$select=Name&$expand=Elements($select=Name,Type,Attributes,Level;$filter=Level eq 7)
