How to change configurations for PAW
- macsir
- Version: PAL 2.0.9
After reading the guide below,
https://www.ibm.com/support/knowledgece ... _file.html
If I change any configuration in paw.ps1, and I open up the administration tool to click on Update button,
The PAW is restarted, but change still hasn't been made? Any idea?
- paulsimon
- Version: PA 2.0.5
Re: How to change configurations for PAW
Further down that guidance it says you can change the parameters by either editing paw.ps1 or by using the PAW Admin Tool. I would suggest using the PAW Admin Tool. That seems to work for us.
- macsir
Alright, what I want to modify is the following bits:
I put# The PAW login session timeout. Default is 60 minutes.
# Amount of time a session can go unused before it is no longer valid.
# Specify a positive integer followed by a unit of time, which can be hours (h),
# minutes (m), or seconds (s). For example, specify 30 seconds as 30s.
# You can include multiple values in a single entry. For example, 1m30s is
# equivalent to 90 seconds.
$env:SessionTimeout="60m"
into paw.ps1 which is supposed to overwrite the default 1 hour and restart the PAW. It looks like the change hasn't take effect after testing. The session was still timeout in one hour.$env:SessionTimeout="2h"
- macsir
Even after reloading the docker image, it still doesn't work. How do I make changes which are not in the PAW admin tool?
- Excel Version: Excel 2007
Run scripts/paw.ps1
Any impacted containers will be re-created with the updated environment variables.
This is the equivalent of clicking the "Start" button in the Admin Tool.
- macsir
Thanks for your advice. I executed scripts/paw.ps1 successfully but the session still failed with authentication error in one hour.
- macsir
The error msg is saying "Unable to refresh contents of widgets. ....httpStatusCode:401,authenticate..."
Looks like the http request of keeping-alive is fixed to 60 minutes currently.
What authentication mode is configured?
- macsir
CAM Security with SSO enabled in this version.
Since the 401 you received was from TM1, not PAW, it appears that the underlying CAM passport timed out. You may need to also adjust that on the CA/BI side.
- macsir
Thanks for that. I tried to change "Inactivity timeout in seconds" in Cognos configuration. It still didn't work.
