PAx - DBRW/DBRS only when requested
PTSD
OLAP Product: ABM Analytics
Version: latest
Excel Version: O365 V1805
Post by PTSD » Mon Jul 16, 2018 4:23 pm
I have an excel file with a lot of DBRW/DBRS formulas (roughly 1000 on each tab). Most of these are also nested in other standard excel formulas. The file works great, except can be very slow at times.
Is there a way to make BBRW/DBRS formulas work only when you want them to, and not contentiously?
Switching to "Manual Calculations" in excel works, but not ideal, since it disables all calculations. I want standard excel formulas to still work, while DBRW/DBRS disabled.
Disconnecting from TM1 server doesn't work because I get #N/A instead of static numbers.
Any ideas on a workaround?
Thanks!
Re: PAx - DBRW/DBRS only when requested
Post by tomok » Mon Jul 16, 2018 4:49 pm
Nesting DBRW/DBR stops Stargate views from working. That's why it is slow. Remove all the nesting and try again.
Version: PAL 2.0
Post by Wim Gielis » Mon Jul 16, 2018 5:18 pm
http://www.wimgielis.com ==> 105 TM1 articles and a lot of custom code
Newest blog article: Looping over input files
PTSD
Version: latest
Post by PTSD » Mon Jul 16, 2018 5:50 pm
Thanks!
It is a bummer though, cause nesting gets me the efficiency. I'll try to reorganize everything and see if I can build it in a similar way with no nesting.
Post by tomok » Mon Jul 16, 2018 6:33 pm
Thanks!
Agreed. There are times when the nesting can be extremely helpful, especially when you are creating input forms. For data retrieval formulas you really should use it sparingly.
PTSD
Version: latest
Post by PTSD » Mon Jul 16, 2018 7:06 pm
Thank you.
It looks like I can easily unnest DBRWs.
Question on DBRSs - obviously hard-coding values is not efficient. If my DBRS formulas are referencing another cell for "send" value - is this considered nesting as well?
Thanks.
Version: PAL 2.0
Post by Wim Gielis » Mon Jul 16, 2018 9:00 pm
Thank you.
What is the DBRS function in TM1 ?
PTSD
Version: latest
Post by PTSD » Mon Jul 16, 2018 11:03 pm
Sorry, I meant DBSW. My bad.
Version: PAL 2.0
Post by Wim Gielis » Tue Jul 17, 2018 7:11 am
In that case, you will link to the cell that is to be sent to TM1. That's not considered nesting.
PTSD
Version: latest
Post by PTSD » Tue Jul 17, 2018 12:39 pm
Weirdly enough, I unnested 70% of the formulas and see no difference in performance. I think it is just the sheer number of formulas on a sheet that effects the performance, not nesting.
Edward Stuart
Version: All
Excel Version: All
Post by Edward Stuart » Tue Jul 17, 2018 1:24 pm
When using TM1Top/ Operations Console can you see how much activity is taking place on TM1 when refreshing these sheets? What kind of performance are you experiencing? (5 seconds, 60 seconds?)
Frequently I've encountered scenarios where the excel calculations/ network speeds have been the bottleneck as opposed to the DBS/R(W) performed by TM1
PTSD
Version: latest
Post by PTSD » Tue Jul 17, 2018 6:27 pm
It is about 1 second delay every time I key in a number and hit enter. Doesn't seem like much, but it is. There are a few thousand formulas on the sheet, half of those are TM1.
Disconnecting from PAx doesn't change anything, which makes me thing it is excel. Never had this problem with SAP excel add-in, similar worksheet.
Version: PAL 2.0
Post by Wim Gielis » Tue Jul 17, 2018 8:43 pm
Do you have calculations on Manual or Automatic ?
PTSD
Version: latest
Post by PTSD » Wed Jul 18, 2018 12:49 pm
Automatic. I do still want standard excel formulas to work.
Version: PAL 2.0
Post by Wim Gielis » Wed Jul 18, 2018 2:19 pm
I see what you mean, and while I don't like it either, suggested mode is manual calcs.
