TM1 Web- #NAME? error in 1 column
cognos4321
Excel Version: Excel2016
Post by cognos4321 » Wed Jun 27, 2018 6:54 pm
One of the Date columns in my Active form displays #NAME? error when opened in TM1Web while it works fine in Perspectives.
Here is the formula which drives the column
=IFERROR(EOMONTH(B29&"/1/"&C29,0),"")
I read that IFERROR formula shows error in TM1Web so I tried removing it by keeping it:
=EOMONTH(B29&"/1/"&C29,0)
Still get the same error.
Please help.
Thanks in advance.
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Re: TM1 Web- #NAME? error in 1 column
Post by gtonkin » Wed Jun 27, 2018 7:04 pm
Have a look at the Excel Functions that are supported in TM1Web - the two you are using are not supported AFAIK.
Version: PAL 2.0
Post by Wim Gielis » Thu Jun 28, 2018 12:17 am
Replace your EOMONTH with DATE with regular numeric arguments. In Excel you can get the last day of a month by asking for day 0 of ‘month + 1’. Not 100% sure if that works in TM1 Web too. If not there are alternatives (e.g. a VLOOKUP in Excel or having an attribute in TM1).
IFERROR can be replaced with IF( ISERROR( ... if it’s not supported in TM1Web.
http://www.wimgielis.com ==> 105 TM1 articles and a lot of custom code
Newest blog article: Looping over input files
cognos4321
Post by cognos4321 » Thu Jun 28, 2018 8:59 pm
Thank you Wim Gielis and gtonkin for your reply.
IF(ISERROR....) worked for me and I calculated the End date of the month by the old way in Excel.
Thanks.
