Warning - read only users
Posted: Thu May 24, 2018 11:21 am
by Wim Gielis
Just one thing I noticed while restricting TM1 users to read-only.
There is a property in the }ClientProperties cube for that. Just set it to 1 for read only.
However, if you do this to yourself, for example being TM1 admin person, you can also remove write rights from yourself / admin persons.
I was caught like that. What helps is writing a TI process to do a CellPutN of 0 in the relevant cell of the }ClientProperties cube. Execute it and you're good again.
Wim
Re: Warning - read only users
Posted: Thu May 24, 2018 5:25 pm
by jim wood
Good to know. Thanks Wim,
Posted: Mon Jun 04, 2018 2:01 pm
by MGrain
I've been there and done that too, caused a moment of panic!
I added a rule to the }ClientProperties cube to set myself back to zero.
Posted: Tue Jun 05, 2018 3:05 pm
by tm123
The other problem with Read Only Users is that the Write-Back will be completely disabled for them. I know we can't complain about this, but since in my models I usually create a cube to store User Selections and use those Selections in MDX Subsets (for example to implement Cascaded Prompts), that becomes an issue
Posted: Wed Jun 06, 2018 8:00 am
by orlando
tm123 wrote: ↑Tue Jun 05, 2018 3:05 pm
Just a quick thought about your issue.
Maybe you could "talk" to this cube via a TI (which read only users can execute). if they can't write ito a cube by the process, it should work to execute runti. the process run via runti (context of an user with hiher rights) could than handle your parameters.
Posted: Wed Jun 06, 2018 1:30 pm
by tm123
orlando wrote: ↑Wed Jun 06, 2018 8:00 am
In my case, in every websheet that requires to cascade prompts, every time the user changes a SUBNM Selection, I have a DBSS that saves the Selected Member in my cube, which works perfect, and I do this not only to make the UI more user friendly, but even to avoid selection of Invalid Intersections. Doing this with a TI process, would require to have an action button clicked every time the user changes any of SUBNM selections.
It would be nice if this READ-ONLY user, does not stop the user from writing to a }Clients base cube
Posted: Wed Jun 06, 2018 2:16 pm
by orlando
tm123 wrote: ↑Wed Jun 06, 2018 1:30 pm
yep. that's true. or ibm should have never introduced them (instead made better prices for a "normal" user)
