Warning - read only users
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Post by Wim Gielis » Thu May 24, 2018 11:21 am
Just one thing I noticed while restricting TM1 users to read-only.
There is a property in the }ClientProperties cube for that. Just set it to 1 for read only.
However, if you do this to yourself, for example being TM1 admin person, you can also remove write rights from yourself / admin persons.
I was caught like that. What helps is writing a TI process to do a CellPutN of 0 in the relevant cell of the }ClientProperties cube. Execute it and you're good again.
Wim
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Re: Warning - read only users
Post by jim wood » Thu May 24, 2018 5:25 pm
Good to know. Thanks Wim,
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
MGrain
Version: Various
Excel Version: Various
Post by MGrain » Mon Jun 04, 2018 2:01 pm
I've been there and done that too, caused a moment of panic!
I added a rule to the }ClientProperties cube to set myself back to zero.
tm123
OLAP Product: tm1, cognos bi
Post by tm123 » Tue Jun 05, 2018 3:05 pm
The other problem with Read Only Users is that the Write-Back will be completely disabled for them. I know we can't complain about this, but since in my models I usually create a cube to store User Selections and use those Selections in MDX Subsets (for example to implement Cascaded Prompts), that becomes an issue
orlando
Version: PAL 2.0
Post by orlando » Wed Jun 06, 2018 8:00 am
Just a quick thought about your issue.
Maybe you could "talk" to this cube via a TI (which read only users can execute). if they can't write ito a cube by the process, it should work to execute runti. the process run via runti (context of an user with hiher rights) could than handle your parameters.
tm123
Post by tm123 » Wed Jun 06, 2018 1:30 pm
In my case, in every websheet that requires to cascade prompts, every time the user changes a SUBNM Selection, I have a DBSS that saves the Selected Member in my cube, which works perfect, and I do this not only to make the UI more user friendly, but even to avoid selection of Invalid Intersections. Doing this with a TI process, would require to have an action button clicked every time the user changes any of SUBNM selections.
It would be nice if this READ-ONLY user, does not stop the user from writing to a }Clients base cube
orlando
Version: PAL 2.0
Post by orlando » Wed Jun 06, 2018 2:16 pm
yep. that's true. or ibm should have never introduced them (instead made better prices for a "normal" user)
