I have installed planning analytics 2.0 and Cognos 11.0.9 and have issues with IE Browser. In IE, TM1 applications were not loading - rendered a blank page and Cognos BI application was working.
IBM has asked us to change document mode to something higher than 7 (under F12) and it did the trick. I have asked IT to roll that to users and they did something and now, and TM1 applications loaded but on clicking an application, it again rendered a blank page. BI which was working now gives a blank page. I have requested them to revert and waiting. I hope this was encountered by many and a solution must have been found. Can someone share the details?
Browser version:11.0.9600.
Cognos server installed on Wondows 2012 R2.
Paul.
Planning Analytics 2.0 - IE Browser issues
Re: Planning Analytics 2.0 - IE Browser issues
Any ideas? There are more than 40 views and no one has encountered the problem?
Luther.
Luther.
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Is your server added to "local intranet" in IE security settings?
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
- Elessar
- Version: 2.0.9
Also, check the compatibility view settings: The site should not be added to the list, and (if it is added to local intranet) the "Display local intranet sites in Comp. view" option should be unchecked
Thanks Elessar.
"local intranet" and compatibility view settings --> "Display local intranet sites in Comp. view" have already been set.
I think our IE has been locked down IE and our IT is not as easy to work with.
Thanks again.
Paul.
Thanks again.
Paul.
Hi Elessar,
Found the solution and it's compatibility settings.
There are two check boxes and settings should be like below.
"Display intranet sites in Compatibility View" should be checked off.
"USe Microsoft microsoft compatibility lists" should be checked on.
Paul.
Paul.
