Return codes and error messages
Moder
Version: 2.0.4
Post by Moder »
I use TM1 IBM Planning Analytics 2.0.4
Is the Return codes and error messages from this link correct ?
https://www.ibm.com/support/knowledgece ... sages.html
I try to test it by made error in processes.
For Example
1. I use ProcessQuit() command to force process to quit.
I suppose to get return code as 9 according to the above link but I got 8 instead.
2. I use ProcessBreak() command to make process finished by break
I got code 7 by doing this while the above link tell me code 7 is something else that's not relevant.
So the question is
Where I can get the correct error message that match the error code ?
I appreciate any help and thanks in advance.
Re: Return codes and error messages
The error codes which that documentation is referring to are the error codes for tm1runti.exe which should not be confused with the exit code for the TurboIntegrator process itself ("process return codes").
If you want to validate the internal integer value of the process return codes this is quite easy to do by just wrapping each return code in NumberToString and outputting it.
e.g.
Then just look in the tm1server.log file
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
Perhaps a useful tip, use a counter dimension (1...n) and add attributes for it to describe the error codes so they can be written to control cubes, output in messages, emails, etc.
Ty
Cleveland, TN
