Query on SwapAliasWithPrincipalName
sreesuku
Version: PAW
Post by sreesuku »
Hi Team,
I have a query on SwapAliasWithPrincipalName.
Does this function swaps the names for all elements in the dimensions with the specified alias names ?
I have created a dimension subset with selected list of elements only and used this as source in the swap TI.
I have put the function in SwapAliasWithPrincipalName(DimName,AiasName,Flag) data tab.
But I have observed that elements names are getting swapped for all elements even though I chose the subset as source
Am I missing anything here ?
Version: PAL 2.0.9.18
Re: Query on SwapAliasWithPrincipalName
Use this function in the Prolog tab, not the Data tab.
It’s done for the entire dimension.
For elements outside the subset, use the same element name in the alias.
IBM Champion 2024
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
If you want to swap aliases based on subsets of elements, create an alias for swapping purposes only. Create your subset, update the alias only for your subset members, the swap the alias. The elements with unpopulated aliases will retain their original name as you probably know.
I think you can use SwapAliasWithPrincipalName in the epilog, but if not, setup a process with the necessary parameters and call it from the epilog.
Ty
Cleveland, TN
