Running PA objects in 10.2
kenship
OLAP Product: Cognos
Version: TM1 10.2
Post by kenship » Fri Apr 06, 2018 12:33 pm
Can cubes, dimensions, rules, TI etc. developed in PA be copied straightly and run in 10.2 w/o any modification?
I believe running 10.2 objects in PA is OK. Not sure the otherwise.
Thanks.
Kenneth
Re: Running PA objects in 10.2
Post by tomok » Fri Apr 06, 2018 1:21 pm
I think as long as you have not used any of the new features of PA then the answer would be yes. Have you tried? I would do that before I would take anyone's word for it.
kenship
Version: TM1 10.2
Post by kenship » Fri Apr 06, 2018 1:35 pm
Truth is we haven't tested it yet. We just want to gather intel from other then plan based on the knowledge.
Thanks!
Post by lotsaram » Fri Apr 06, 2018 2:07 pm
Answer is no unless it is the latest version of 10.2.2 FP7 plus fix packs.
There was a recent IF to 10.2.2 FP7 which correlated to a IF of PA 2.0.2 or 2.0.3 which introduced a change to format of cube files. If you try and load a .cub file saved in a version since this update in an older version you will get a "file format too new" error and the cubes won't load.
kenship
Version: TM1 10.2
Post by kenship » Fri Apr 06, 2018 2:10 pm
Thanks for the information. I'll have to check the version of PA and note this issue.
