TM1 Active Form is returning Zeros even when suppress zero is set to True/1. Please help
Ashleigh W
Version: TM1 Perspectives 10
Excel Version: Excel 2016
Post by Ashleigh W » Wed Mar 14, 2018 9:11 am
Version: 9.5.2 64 bit moving to 10.2.2
Re: TM1 Active Form is returning Zeros even when suppress zero is set to True/1. Please help
Post by Alan Kirk » Wed Mar 14, 2018 9:25 am
The usual cause is that the values aren't really zero but really tiny way-down-in-the-decimal-places values, usually derived from rules. I'd slice the view in question and format Excel to show the maximum number of decimal places possible.
Ashleigh W
Post by Ashleigh W » Wed Mar 14, 2018 9:31 am
Thank you Alan..that answer the way tm1 might be behaving but I do not see any decimal values even if i maximize the decimal places to 20...any hack / tips for this?
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC » Wed Mar 14, 2018 12:15 pm
HI,
Just as a further check have you tried dividing something by the value? If it returns a div error then at least you know for sure the value is zero.
Also I presume you haven't manually changed the TM1RPTVIEW suppress zero parameter at all? If so did you rebuild the worksheet or just recalculate?
cheers, Mark
Willi
Version: 9.5.2
Post by Willi » Thu Mar 15, 2018 9:24 am
Is the column in question the only column wich reference the TM1RPTVIEW-Cell? If not, all columns have to be zero that the line is suppressed.
Ashleigh W
Post by Ashleigh W » Thu Mar 15, 2018 11:13 am
HI,
cheers, Mark
It already has suppress enabled. I could be missing something
=TM1RPTVIEW("server:dummyCubename:1", 1, TM1RPTTITLE("server:Version....
Ashleigh W
Post by Ashleigh W » Thu Mar 15, 2018 11:14 am
The Active form has only two columns and both are referenced to TM1RPTVIEW
Willi
Version: 9.5.2
Post by Willi » Thu Mar 15, 2018 12:38 pm
And are both colums pretended to be zero (or empty)? If one of them is not zero/empty the line is shown
Mark RMBC
Version: 10.1.1
Post by Mark RMBC » Thu Mar 15, 2018 12:58 pm
Just want to know if when you open the active form in perspectives and if you do a alt-F9 to rebuild the sheet does it still show the zero values?
cheers, Mark
Ashleigh W
Post by Ashleigh W » Fri Mar 16, 2018 6:03 am
Yes I tried clearing the data and rebuilding it still the same. they are zeros. I tried division and it return #DIV/0! error.
I tried using public subset of level 0 for dimension still same result, tried MDX still the same.
Post by declanr » Fri Mar 16, 2018 8:37 pm
Apologies to ask a basic question but it is actually something Willi has asked twice in this thread and unless I am missing it I can't see an answer...
is the issue that a row containing all zeroes is still showing? Or are you expecting a column containing all zeroes to be hidden?
If its the latter, active forms can only suppress rows not columns.
Again apologies if you are already aware of this but its always worth going with an Occam's razor approach to problem solving.
Willi
Version: 9.5.2
Post by Willi » Mon Mar 19, 2018 7:42 am
And additionally did you checked that there is no hidden column in the form wich also references to the TM1RPTVIEW?
