TM1RunTI Won't Work or Return Error
Posted: Sat Mar 10, 2018 6:11 am
Just getting started on trying TM1RunTI. I've read the documentation and reviewed a few forum posts, but cannot get it to work. When I run it from a command prompt, I don't get an error or success message. Instead it just returns what appears to be help information.
Here's what I entered at the command prompt:
Here's what is contained in the "MyTM1RunTI.ini" configuration file
Here's what it returned:
c:\program files\ibm\cognos\tm1_64\bin64>tm1runti -i "c:\username\documents\MyTM1RunTI.ini"
[TM1RunTI]
process="Build Dimension"
connect=Development
[Process - Build Dimension]
pDimName="MyDimension"
[Connect – Development]
adminhost="servername.sub.mydomain.com"
server="MyTM1ServerInstance"
user="admin"
pwd="apple"
tm1runti -?
or tm1runti -help
or tm1runt1 [<cmd_parm>...] [<ti_parm>...]
where <cmd_parm> is one of:
-i <filespec>
-process <string>
-chore <string>
-connect <string>
<connect_parm>...
where <ti_parm> is:
<parm_name> '=' <parm_value>
where <connect_parm> is one of:
-adminhost <string>
-server <string>
-user <string>
-securitymode
-retryattempts
-retryinterval
<password_parm>
-AdminSvrSSLCertAuthority <filespec>
-AdminSvrSSLCertID <id>
-AdminSvrSSLCertRevList <filespec>
-AdminSvrSSLExportKeyId <id>
-ExportAdminSvrSSLCert <T|F>
-CAMNamespace <string>
where <password_parm> is one of:
-pwd <string>
-passwordfile <filespec> -passwordkeyfile <filespec>PA
