Hi everybody,
I am using TM1 with Cognos Analytics and something wrong is going on.
I read about the control cube }HierarchyProperties and I am aware that the name that appears on Cognos Analytics on hierarchy is the name that I put on levels of this cube for each dimension that exists on model.
The problem is that the name is changing on this control cube on TM1 and until I understand it only changes if I go there and do it.
Does everyone knows if this can happens if a run any kind of process or something?
And the problem of changing the name alone is that my dash on Cognos needs to be set again.
Thanks a lot,
JR
HierarchyProperties
- Version: 10.2
- Excel Version: 2013
- macsir
- Version: PAL 2.0.9
Re: HierarchyProperties
According to my past experience, the level name you put there won't be changed. Not sure how it is changing in this version.
I know levels are useful to Cognos reports but I would prefer to use children function from the root element in Cognos reports to get there. In that way, your reports don't have to reply on this HierarchyProperties cube.
- paulsimon
- Version: PA 2.0.5
Is the problem possibly more related to alternate hierarchies in the TM1 dimension, which means that level naming can vary according to which alternate hierarchy you are viewing the element in?
- Version: 10.2
Hi Paul,
In my case, I have two dimensions with different names, but with the same elements.
And I wanna a specific name on hierachyproperties for one of these two dimensions, but the name is changing for this one that I don’t want, so I don’t know how to proceed.
But based on what I have read the name that I put on level on control cube is not a dimension, but just a name that shows up on Cognos Analytics.
Anyway, maybe I am missing something out.
Thanks!
Thanks!
- paulsimon
- Version: PA 2.0.5
Hi Jorge
You are naming the level in the hierarchy within the dimension. The dimension is what you select in }Dimensions which is one of the dimensions of the }HierarchyProperties cube.
This level name will appear in Cognos Analytics previously known as Cognos BI.
- Version: 10.2
Hi Paul,
I understood what happened. I have a process running everynight with a different name that I want and it was using "refreshmdxhierarchy" on epilog.
Now I've changed it on process and hope to keep right.
Gabriel
Gabriel
