TM1 dimension elements not appearing in Cognos Report Studio
Paul-TM1
Post by Paul-TM1 » Mon Feb 12, 2018 4:16 pm
Hi Gurus,
I have a question about some TM1 dimension elements not appearing in Cognos Report Studio. If add/delete new dimension elements, they appear/disappear instantly. There is no element security on the dimension. I have combed enough for where it cloud have gone wrong. Can someone help? I have published the framework model again.
Any help is greatly appreciated.
We are on TM1 10.2.2 FP7 and on Cognos BI - 10.2.1 FP13 all windows.
Paul.
paulsimon
Version: PA 2.0.5
Re: TM1 dimension elements not appearing in Cognos Report Studio
Post by paulsimon » Mon Feb 12, 2018 9:20 pm
Try issuing a RefreshMDX statement in the Epilog of the Dimension Update process
BariAbdul
OLAP Product: TM1,Cognos
Version: 9.5.2
Post by BariAbdul » Tue Feb 13, 2018 6:02 am
Please go through below Tech note, it basically talks about what Paul has advised you.
https://www.ibm.com/support/knowledgece ... n2835.html Thanks
Paul-TM1
Post by Paul-TM1 » Mon Feb 26, 2018 9:06 pm
Thanks everyone for the inputs.
I found that all elements that are not visible are available under consolidated elements. To test, I deleted a consolidated element and the child elements were visible in their normal locations. I will let IBM check this further.
Luther.
