degrading performance issue with TI
nehagandhi
Version: 2.0.2
Excel Version: 00
Post by nehagandhi » Fri Jan 19, 2018 4:39 pm
All,
we are experiencing increased run times for TI processes when run multiple times.
however if the server is rebooted, the performance gets better.
Can you help me understand what could be happening over run time that it slows following runs.
Neha
Re: degrading performance issue with TI
Post by tomok » Fri Jan 19, 2018 5:22 pm
Have you checked your memory? If it is slowing down after repeated processing that would be the first place I would look. You've probably used up all available RAM for stargate views and now it is having to resort to paging.
bhushpar82
Version: 9.5.2,10.2.2
Post by bhushpar82 » Thu Jan 25, 2018 8:07 pm
Series of steps:
- Check Ram usage as pointed out in above reply.
- I would also check if there are parallel TIs running in TM1Top (no locks).
- What is this TI doing? ensure views are created correctly.
Empty mind is Devil's Workshop, but my devils creative!!
