Report view slowed down after upgrade TM1 version 10.2.2 to PA 2.0.3
looksout17
OLAP Product: Planning Analytics and TM1
Version: 2.0.3 and 10.2.2
Excel Version: 14
Post by looksout17 » Fri Jan 19, 2018 5:46 am
I have upgraded tm1 version 10.2.2 to PA 2.0.3. But there is one critical report view slowed down, where in the condition before the upgrade is 15-20 seconds and after the upgrade to 25-30 seconds. is there any cause that makes a performance difference? is there a custom configuration that needs to be set in PA 2.0.3 ?
Thanks.
Willi
Version: 9.5.2
Re: Report view slowed down after upgrade TM1 version 10.2.2 to PA 2.0.3
Post by Willi » Wed Jan 24, 2018 12:31 pm
Do you probably need adjustments on VMM and VMT in the }CubeProperties Cube?
MEB
Excel Version: Office 2010
Post by MEB » Wed Jan 24, 2018 2:08 pm
Could you expand on what kind of adjustments might be needed?
Willi
Version: 9.5.2
Post by Willi » Wed Jan 24, 2018 3:45 pm
I think this Blog-Post explains the use of this 2 entries much better than I can. So probably the upgrade gets the used cube a bit over the threshhold.
