After log in on tm1web I'm facing the following error:
The TM1Web service parameter was not specified or is not one of the configured locations
We already checked and the URL on BI server is okay.
Can anyone give another idea of what is happening and what could be checked?
Thanks a lot,
JR
TM1Web Error
- Version: 10.2
- Excel Version: 2013
- macsir
- Version: PAL 2.0.9
Re: TM1Web Error
check your pmhub.html and planning.html on cognos server to include all possible URLs (with or without full domain names)
- Version: 10.2
Re: TM1Web Error
hi, thanks for the reply.
we have tried that and it is not working. We don't have the file pmhub.html, we have only tm1web.html and planning.html.
could be that the problem or there is something else?
tks.
tks.
- macsir
Re: TM1Web Error
Sorry, my bad. Missed tm1web.html file. But you should have these three file to allow CAM to work properly.
Have you configured TM1WEB to work ever? If not, refer to http://www-01.ibm.com/support/docview.w ... wg21958925
Also, while testing, you should use IE, Chrome and Firefox to do full testing. Sometimes, it is just because of the cookies/cache in the one browser, which caused the issue.
- Version: 10.2
Re: TM1Web Error
hi, the ip number was wrong and now it is working!
very good! thanks a lot for your help.
Happy holidays.
JR
Happy holidays.
JR
- macsir
Re: TM1Web Error
Glad you found it. It is very common mistake. Rather than using IP, I still recommend to use domain name in case you have IP address or host change.Jorge Rachid wrote: ↑Fri Dec 29, 2017 1:17 pm hi, the ip number was wrong and now it is working!
Happy holidays.
JR
