Hi ,
I have read the IBM proven practices on feeders on recommendation of a forum member and half way through and they explain the basics clearly .
I have an issue now with my feeder not being fed and disappears on zero suppression .
I have a measure which gives the turn around time and other measure which count the cases , so I will need a variable which will calculate the total turnaround time taken for that month and divide by total number of cases for that month .
so simple rule :
SkipCheck;
['Average TurnAround Time' ] = DB('Dispute Data', !Customers SoldTo Only, !Currencies, !Months, !Dispute Case ID, !Dispute Case Status, !Dispute Person Responsible, !Dispute Processor, !Dispute Reason, !Dispute Root Cause Code, 'TurnAround Time') \ DB('Di
spute Data', !Customers SoldTo Only, !Currencies, !Months, !Dispute Case ID, !Dispute Case Status, !Dispute Person Responsible, !Dispute Processor, !Dispute Reason, !Dispute Root Cause Code, 'Cases with TurnAround');
And I have a feeder :
['TurnAround Time'] =>['Average TurnAround Time' ] ;
I just used one element in the division to feed my Average TurnAroundTime.
Now I have attached the results saying not fed , but when I click on check feeders at lowest level
Its showing up
the calculation taking the value of DB('Dispute', All dimension , 'AverageTurnArounTime');
It should take the turnaroundtime/caseswith turnaround right?
Attached both the check feeder and cube data screenshot .
I also tried to change my feeder to below as well :
['TurnAround Time'] =>DB('Dispute Data', !Customers SoldTo Only, !Currencies, !Months, !Dispute Case ID, !Dispute Case Status, !Dispute Person Responsible, !Dispute Processor, !Dispute Reason, !Dispute Root Cause Code, 'Average TurnAround Time');
But same results not fed.
Appreciating any help !!
Feeders - not fed
- OLAP Product: Tm1
- Version: 9.5
Feeders - not fed
- CheckFeeders.png (15.88 KiB) Viewed 2464 times
- RuleTracer.png (47.77 KiB) Viewed 2464 times
- orlando
- Version: PAL 2.0.8
Re: Feeders - not fed
hi,
i would say the feeder "['TurnAround Time'] =>['Average TurnAround Time' ] ;" looks good.
What do you see, wenn you "Trace Feeder" from the elment "TurnAround Time".
What happens when you restart the database?
Another idea:
"Average TurnAround Time" as a consolidated element with childs "TurnAround Time" and "Cases with TurnAround". then you do not need the feeders because the hierarchy feeders itself.
Another idea:
- Version: PAW 2.0.8
- Excel Version: 2019
Just came across very good article on Feeders, please go through it:
https://code.cubewise.com/blog/how-to-f ... and-fix-it Thanks
