unwinding certain elements issue
- OLAP Product: Tm1
- Version: 9.5
Hi ,
I have a dimension with hierarchy like below .
All customers
America
EMEA
ASIA
Under each country i have 5 levels.
unwinding is done because customers might swap between one parent to other at same level.
I want to do unwinding only for customer under America and one region under asia where swapping occurs.
My unwinding code is below
vMax = DIMSIZ(vDim);
vCount = 1;
WHILE (vCount <= vMax);
vElem = DIMNM(vDim, vCount);
vMaxParents = ELPARN(vDim, vElem);
if((ELISANC(vDim,'AMERICAS',vElem)=1)%(ELISANC(vDim,'Region - A00',vElem)=1));
WHILE (vMaxParents>0);
vParent = ELPAR(vDim, vElem, vMaxParents);
DimensionElementComponentDelete(vDim, vParent, vElem);
vMaxParents = vMaxParents - 1;
END;
ENDIF;
vCount = vCount + 1;
END;
this unwinding only takes my america's first child and puts is outside , then the first childs children are not unwinded.
Meaning america has region 1 to region7 and region 1 has 4 subregions.
the region 1 to region 7 are unwinded , but its children are still maintained.
How do I unwind all elements under Americas
Any help is appreciated.
All customers
America
EMEA
ASIA
vCount = 1;
END;
ENDIF;
END;
- gtonkin
Re: unwinding certain elements issue
Will refer you to the search function as this has been covered many times over the years - your basic problem is that you are creating fragments by unwinding from the top down-you need to work backwards through the dimension/hierarchy in most cases.
Edit: Could you not use MDX to create a subset with the full hierarchies you need and then unwind them?
- Version: PAW 2.0.8
- Excel Version: 2019
Might be not exactly what you looking for ,but along the similar lines,might help:
http://www.tm1forum.com/viewtopic.php?f=3&t=13716 Thanks
- OLAP Product: Tm1
- Version: 9.5
can anyone share a code snippet for unwinding using mdx .
Say assume I have a dimension where i unwind only below code
Americas->V00,V01
All elements under this 2 regions V00 and V01 .
I have a mdx like below
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER({[Customers SoldTo].[Region - V00],[Customers SoldTo].[Region - V01]}, ALL, RECURSIVE )}, 0)}
Now how to unwind the elements meaning seperating parent from child .
say I use this subset as a source for TI which will have all elements under V00 and V01.
How would i associate the parent and child for sepearting them from the consolidation ?
Americas->V00,V01
- OLAP Product: Tm1
- Version: 9.5
I got to work used subsetsize and get element name and used the same process on it .
- OLAP Product: Cognos
- Version: 10.1.1
Sir Pls share your code,it going to help me and others
- Version: 10.1.1
Analytics123 please share code
- orlando
- Version: PAL 2.0.8
i'm using this code to unwind a hierarchy (or parts from that). I always move the unwinded elmenets to a new parent called "trash".
Then i'm always sure, that i don't lose any elements.
sDim = 'MyDim';
sTopNode='MyTopNode';
sMDX ='{HIERARCHIZE({TM1DRILLDOWNMEMBER( {['|sDim|']['|sTopNode|']}, ALL, RECURSIVE )})}';
sTrash = 'Trash';
sSub = GetProcessName;
if(SubsetExists(sDim, sSub)=1);
SubsetDestroy(sDim, sSub);
endif;
SubSetCreateByMDX(sSub, sMDX);
SubSetElementInsert(sDim, sSub, sTopNode, 1);
SubSetElementDelete(sDim, sSub, 1);
DimensionElementInsert(sDim, '', sTrash, 'N');
iCounter = SubSetGetSize(sDim, sSub);
i=1;
while(i<=SubSetGetSize(sDim, sSub));
sElem = SubsetGetElementName(sDim, sSub, iCounter);
iPar = ElParN(sDim, sElem);
p=1;
if(iPar >=1);
while(p<=iPar);
sParent = ELPAR(sDim, sElem, p);
if(ELISANC(sDim, sTopNode,sParent)=1);
DimensionElementComponentAddDirect(sDim, sTrash, sElem,1);
DimensionElementComponentDeleteDirect(sDim, sParent, sElem);
p=9999999999;
endif;
p=p+1;
end;
endif;
i=i+1;
iCounter = iCounter-1;
end;
sDim = 'MyDim';
sTrash = 'Trash';
endif;
i=1;
p=1;
if(iPar >=1);
while(p<=iPar);
p=9999999999;
endif;
p=p+1;
end;
endif;
i=i+1;
end;
- Version: 10.1.1
thank you Mr. orlando.i am disappointed with Analytics123 despite my several request he did not share the code,i suprised how can he expect help from others.
- OLAP Product: Tm1
- Version: 9.5
Moh,
I was out of town , here you go .
DIMENSIONSORTORDER(vDim,'','','ByHierarchy','ASCENDING');
vMax = SubsetGetSize(vDim,vSubsetName);
vCount = 1;
vElem = SubsetGetElementName(vDim,vSubsetName,vCount);
END;
END;
vCount = 1;
END;
END;
- Version: 10.1.1
Thank you sir
