unwinding certain elements issue
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Fri Dec 01, 2017 2:04 am
Hi ,
I have a dimension with hierarchy like below .
All customers
America
EMEA
ASIA
Under each country i have 5 levels.
unwinding is done because customers might swap between one parent to other at same level.
I want to do unwinding only for customer under America and one region under asia where swapping occurs.
My unwinding code is below
vMax = DIMSIZ(vDim);
vCount = 1;
WHILE (vCount <= vMax);
vElem = DIMNM(vDim, vCount);
vMaxParents = ELPARN(vDim, vElem);
if((ELISANC(vDim,'AMERICAS',vElem)=1)%(ELISANC(vDim,'Region - A00',vElem)=1));
WHILE (vMaxParents>0);
vParent = ELPAR(vDim, vElem, vMaxParents);
DimensionElementComponentDelete(vDim, vParent, vElem);
vMaxParents = vMaxParents - 1;
END;
ENDIF;
vCount = vCount + 1;
END;
this unwinding only takes my america's first child and puts is outside , then the first childs children are not unwinded.
Meaning america has region 1 to region7 and region 1 has 4 subregions.
the region 1 to region 7 are unwinded , but its children are still maintained.
How do I unwind all elements under Americas
Any help is appreciated.
Version: PAL 2.0.3
Excel Version: 2016 64-bit
Re: unwinding certain elements issue
Post by gtonkin » Fri Dec 01, 2017 5:18 am
Will refer you to the search function as this has been covered many times over the years - your basic problem is that you are creating fragments by unwinding from the top down-you need to work backwards through the dimension/hierarchy in most cases.
Edit: Could you not use MDX to create a subset with the full hierarchies you need and then unwind them?
BariAbdul
OLAP Product: TM1,Cognos
Version: 9.5.2
Post by BariAbdul » Fri Dec 01, 2017 12:29 pm
Might be not exactly what you looking for ,but along the similar lines,might help:
http://www.tm1forum.com/viewtopic.php?f=3&t=13716 Thanks
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Fri Dec 01, 2017 3:03 pm
can anyone share a code snippet for unwinding using mdx .
Say assume I have a dimension where i unwind only below code
Americas->V00,V01
All elements under this 2 regions V00 and V01 .
I have a mdx like below
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER({[Customers SoldTo].[Region - V00],[Customers SoldTo].[Region - V01]}, ALL, RECURSIVE )}, 0)}
Now how to unwind the elements meaning seperating parent from child .
say I use this subset as a source for TI which will have all elements under V00 and V01.
How would i associate the parent and child for sepearting them from the consolidation ?
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Fri Dec 01, 2017 6:56 pm
I got to work used subsetsize and get element name and used the same process on it .
Moh
OLAP Product: Cognos
Version: 10.1.1
Post by Moh » Sat Dec 02, 2017 6:03 am
Sir Pls share your code,it going to help me and others
Moh
Version: 10.1.1
Post by Moh » Wed Dec 06, 2017 2:51 am
Analytics123 please share code
orlando
Version: PAL 2.0
Post by orlando » Wed Dec 06, 2017 8:55 am
i'm using this code to unwind a hierarchy (or parts from that). I always move the unwinded elmenets to a new parent called "trash".
Then i'm always sure, that i don't lose any elements.
sDim = 'MyDim';
sTopNode='MyTopNode';
sMDX ='{HIERARCHIZE({TM1DRILLDOWNMEMBER( {['|sDim|']['|sTopNode|']}, ALL, RECURSIVE )})}';
sTrash = 'Trash';
sSub = GetProcessName;
if(SubsetExists(sDim, sSub)=1);
SubsetDestroy(sDim, sSub);
endif;
SubSetCreateByMDX(sSub, sMDX);
SubSetElementInsert(sDim, sSub, sTopNode, 1);
SubSetElementDelete(sDim, sSub, 1);
DimensionElementInsert(sDim, '', sTrash, 'N');
iCounter = SubSetGetSize(sDim, sSub);
i=1;
while(i<=SubSetGetSize(sDim, sSub));
sElem = SubsetGetElementName(sDim, sSub, iCounter);
iPar = ElParN(sDim, sElem);
p=1;
if(iPar >=1);
while(p<=iPar);
sParent = ELPAR(sDim, sElem, p);
if(ELISANC(sDim, sTopNode,sParent)=1);
DimensionElementComponentAddDirect(sDim, sTrash, sElem,1);
DimensionElementComponentDeleteDirect(sDim, sParent, sElem);
p=9999999999;
endif;
p=p+1;
end;
endif;
i=i+1;
iCounter = iCounter-1;
end;
Moh
Version: 10.1.1
Post by Moh » Wed Dec 06, 2017 3:06 pm
thank you Mr. orlando.i am disappointed with Analytics123 despite my several request he did not share the code,i suprised how can he expect help from others.
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Wed Dec 06, 2017 6:20 pm
Moh,
I was out of town , here you go .
DIMENSIONSORTORDER(vDim,'','','ByHierarchy','ASCENDING');
vMax = SubsetGetSize(vDim,vSubsetName);
vCount = 1;
vElem = SubsetGetElementName(vDim,vSubsetName,vCount);
END;
END;
Moh
Version: 10.1.1
Post by Moh » Sun Dec 17, 2017 12:21 pm
Thank you sir
