Error while updating application rights
TTH
Post by TTH »
I'm having an error while updating application rights from file. The error I receive is the following:
ti_INTERNAL[NA | }tp_util_update_hierarchy_from_file | ProcessAborted ]
And when I look through log files, }tp_util_update_hierarchy -process is giving the following error:
Error: Prolog procedure line (102): Cannot convert string "1.0" to a real number
This is not occuring to all of my applications. When I delete the application and create it again, everything works fine, but when I try to refresh rights, same occurs again. Has anyone faced similar problem? What should I do to solve problem?
System info:
TM1 10.2.2 FP5
OS: Windows Server 2008 R2 Standard 64bit
Thank you in advance!
