TM1 Web - limit access to instance
AskAndAnswer
Version: 2.0...
Post by AskAndAnswer »
Good afternoon,
There are several options to configure TM1 Web logon screen. I can update tm1web_config.xml to set a default admin host and tm1 instance, but I am not sure how to limit the number of instances that can be available on one admin host. For example, I have DEV, QA and PROD on the same admin host, all of them have TM1 Web applications, but I want users to see only QA and PROD. In other words, when they open http://webserver:9510/tm1web/, they should see a drop-down with only two instances out of three. Is it doable? What if I want to default to QA now and then change the default to PROD later, but still always have two instances available for login?
Thank you.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: TM1 Web - limit access to instance
Post by BariAbdul »
There are ways to do as below:
https://www.ibm.com/support/knowledgece ... 500c8.html Thanks
