PA 2 SSL_TLSv2
st2000
OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
Version: 10.2.0 FP3
Excel Version: Excel 2013
PA 2 SSL_TLSv2
Post by st2000 » Wed Nov 08, 2017 9:29 am
Hello all,
I just installed PA 2.0.3 into a Linux VM (CentOS 7 on Virtualbox 5.2, Host Win10 Pro 64 Bit). It works as I can start Cognos Configuration and the processes (Admin Server, TM1 Server, Planning Sample). I configured the support for pre-TLS1.2 clients to true.
But although I can see the login page (localhost:9510/tm1web/), after typing the topmost parameter for Adminhost (name, IP or localhost), I get a window showing just: SSL_TLSv2. Same behaviour inside of the VM (Firefox) and outside from the host PC (IE 11).
This indicates a problem with certificates, but a login to applications like PMHUB works. tm1_inst (for PA V2 R0, latest I found at IBM) guides how to import a certificate using a keytool command to run from the JAVA_HOME folder, but at first it asks if I trust the file ("yes"), then it says JAVA I/O Error, no such file. I use the preinstalled JAVA 1.8 already contained into CentOS 7. Is there anything obvious I could have missed?
Stefan
Stefan
guntupalli
OLAP Product: tm1
Re: PA 2 SSL_TLSv2
Post by guntupalli » Mon Jan 15, 2018 6:53 am
i came across this even though getting the same error.
1.did you run the keytool command from 'bin' location that is associated to JAVA_HOME?
2.check the permissions before going to execute the command..
keep posting.
Best Regards
Best Regards,
Guntupalli
