Unwinding specific elements in GLobal Customer diension
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 »
Hi ,
I have a customer dimension with customers from US, Germany and Asia . The Us customers might swap over the hierachy and other two customers are loaded in run time .
In the first process I am unwinding all the elements and adding only us elements and Germany and Asia parent nodes .
All -Customers -> America
Germany
Asia
Under America all customers are updated and then while cube load other two customers are added under germany and asia .
Now on the next day unwinding does all the data and I wanted only the customers under America to unwind .
Below is my code to unwind :
DIMENSIONSORTORDER(vDim,'','','ByHierarchy','ASCENDING');
vMax = DIMSIZ(vDim);
vCount = 1;
WHILE (vCount <= vMax);
vElem = DIMNM(vDim, vCount);
vMaxParents = ELPARN(vDim, vElem);
WHILE (vMaxParents>0);
vParent = ELPAR(vDim, vElem, vMaxParents);
DimensionElementComponentDelete(vDim, vParent, vElem);
vMaxParents = vMaxParents - 1;
END;
vCount = vCount + 1;
END;
Is there a way to ignore all the elements under Asia and germany
Re: Unwinding specific elements in GLobal Customer diension
Why not use a subset as the basis for your unwinding with only the elements you want to unwind otherwise use ELISANC to check if an element is part of the rollups to skip?
BR, George.
