Count the number of Accounts for each agency
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Fri Oct 20, 2017 7:22 pm
Hi ,
I have a hierrachy like Region, Agency,Subregion, Rep and accounts .
The user wants the count of number of accounts under each agency .
Is there a TI function I can use which will take the agency as input and give me the count of accounts under that agency .
Re: Count the number of Accounts for each agency
Post by tomok » Fri Oct 20, 2017 7:32 pm
No, but you can always write your own. If it was me I would have a TI that takes the agency as an input, builds an MDX-based subset on the dimension that does a TM1DRILLDOWNMEMBER on that input agency and then filters to only 0 level. Then you can use SUBSETGETSIZE on that subset. That will give you the number of accounts under the agency.
BariAbdul
OLAP Product: TM1,Cognos
Version: 9.5.2
Post by BariAbdul » Sat Oct 21, 2017 3:48 am
Please go through the MDX primer.doc for detail explaination of MDX functions with context to TM1. Thanks
MDX_Primer.doc
(669 KiB) Downloaded 21 times
