VBA API: TM1_API2HAN() vs TM1SystemOpen()
orlando
Version: PAL 2.0
Post by orlando » Thu Oct 19, 2017 1:53 pm
Hello!
I have a very old (around 12 to 14 year) planning environment, that uses a lot of VBA.
The user connection is made via VBA (Perspectives I also loaded by a VBA Code) and works fine. The Excelsheets, that are used for planning, are very static and also created by VBA. So, in this old world everything is fine. If I provide active forms to the users, the active forms are not working. It looks like an active form when you forget to start perspectives.
If I change the VBA connection to the second sub – active form work – but the old world doesn’t.
I even tried to put “hUser = TM1_API2HAN()” at the end of the second Sub – with no effect.
Does anybody have an Idea how I could keep the “old world” alive and can make a connect via VBA to use active forms.
Thanks a lot in advance!
### SUB 1
Sub verbindung_herstellen()
Dim AdminHostName, ServerName As String
AdminHostName = ThisWorkbook.Worksheets("Adr").Range("_adm_1")
ServerName = ThisWorkbook.Worksheets("Adr").Range("_sr_1")
ServerName = Left(ServerName, Len(ServerName) - 1)
hPool = TM1ValPoolCreate(hUser)
vServerName = TM1ValString(hPool, Trim(ServerName), 0)
vClientName = TM1ValString(hPool, Trim(UserName), 0)
vClientPassword = TM1ValString(hPool, Trim(Password), 0)
hServer = TM1SystemServerConnect(hPool, vServerName, vClientName, vClientPassword)
If haendel_testen(hServer, "hServer") = "The hServer handle contains an error code." Then
MsgBox "Keine Verbindung"
End If
End Sub
### Sub2
Sub con
hUser = TM1SystemOpen()
'AdminHostServer angeben
Call TM1SystemAdminHostSet(hUser, AdminHostName)
ServerCount = TM1SystemServerNof(hUser)
'Einen ValuePool-Handle erstellen
MsgBox AdminHostName + " " + ServerName + " " + UserName + " " + Password
'Am TM1-Server anmelden
End Sub
