replace a subset value in db function
Analytics123
OLAP Product: Tm1
Version: 9.5
Post by Analytics123 » Thu Oct 12, 2017 12:27 pm
I have to replace a subset value in place of hard coded month in the below DB expression
['Average DSO'] =DB('AR History', !Customers SoldTo Only, 'US01', 'Jul 2017', 'All Currencies', 'Local Currency', 'ASSETS', 'All Customer Types', '6 month DSO');
I have a subset name called Months - Prior Month which has one item .
If we cannot use the dynamic subset in rules, how can i generate the last completed month which is sep 2017 with in rule.
jim wood
Version: TM1 10.2.2
Location: 1639 Route 10, Suite 107, Parsippany, NJ, USA
Re: replace a subset value in db function
Post by jim wood » Thu Oct 12, 2017 12:32 pm
Lookup up cube may be?
Application Consulting Group (ACG) TM1 Consulting
OS: Windows 10 64-bit. TM1 Version: 10.2.2
Post by tomok » Thu Oct 12, 2017 12:44 pm
You have two options that I can think of; 1) have a lookup cube (as has already been mentioned), or 2) create an alias on the time dimension and make the alias value for the current month equal to "Current Month". That way you can reference "Current Month" in your rule. When the next month rolls around you take off the alias for the old month and make the alias value for the next month be "Current Month". They both work so it comes down to personal preference.
ascheevel
Version: 11.2
Post by ascheevel » Thu Oct 12, 2017 12:45 pm
Consolidation called 'Prior Month' would work too.
jim wood
Version: TM1 10.2.2
Post by jim wood » Thu Oct 12, 2017 4:36 pm
I always lean towards a lookup cube as it can be used within multiple cubes if you don't have a shared time dimension or even multiple time dimensions within the same cube.
