TM1 instances are running in cognos configuration but not appearing in TM1 architect.
atulawnish
Post by atulawnish » Thu Oct 12, 2017 7:16 am
I logged in to a new server where TM1 has been installed.
I have noticed that all TM1 instances like Go_Socard,Go_newSales etc are running/are in start mode in cognos configuration/Services but i am unable to see them in Architect.I have created a test instance also,the problem persists.
I am not sure if SSL has been upgraded here or not.If this is due to SSL .Please suggest how to check if the SSL has been upgraded or not.
I am aware of steps to upgrade it.
Thanks in advance...cheers. :) :)
Awnish
atulawnish
Re: TM1 instances are running in cognos configuration but not appearing in TM1 architect.
Post by atulawnish » Thu Oct 12, 2017 8:29 am
Got steps to verify certificate installed.
url is http://www-01.ibm.com/support/docview.w ... wg21993829
hopefully it will be helpful for everyone.
Still i am waiting for revert to my issue pls do revert if anyone knows the soltn.
-Awnish
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg » Wed Oct 18, 2017 10:54 am
also check you architect version and tm1 version.
architect <= 10.2.2 fp4 not see tm1 instance run on 10.2.2 fp4>
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Tue Oct 24, 2017 4:53 am
also check your admin host address is right or not or ports are open on the server or the server has multiple IP addresses or not.
