fileexists and dimensionexists
raman
OLAP Product: tm1
Post by raman »
i am new to tm1. i want to make a ti process which first check wether the file exists or not, if fileexists then process should continue otherwise it should exit with a suitable message.then it should check for dimension and create or update according to availability of dimension.
Edward Stuart
Version: All
Excel Version: All
Re: fileexists and dimensionexists
Post by Edward Stuart »
What have you tried so far?
Have you seen the request for assistance guidelines
Have you tried googling for any information?
https://www.google.co.uk/search?q=cogno ... e&ie=UTF-8
raman
OLAP Product: tm1
Post by raman »
i tried this
if(FileExists('filename')=1);
ExecuteProcess('dim_name');
else;
ProcessQuit;
endif;
but this one is sending the process into loop
and for dimension part i did
if(dimesnionexists('dim_name')=0);
dimensioncreate('dim_name');
else;
dimensionupdatedirect('dim_name');
endif;
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
Have you defined the path correctly in the TI :
FileExists('C:\tm1s7\pdata\model.dim');
And created a wapper process to perform the evaluation in the PROLOG:
IF(FileExists('FILENAME') =1);
ExecuteProcess('Load Process Name Here');
ELSE;
ProcessQuit;
ENDIF;
As for the second part:
This feature can be used extensively after direct dimensioning with DimensionElementInsertDirect, DimensionElementDeleteDirect, DimensionElementComponentAddDirect, DimensionElementComponentDeleteDirect and / or DimensionTopElementInsertDirect. Calling the DimensionUpdateDirect function causes the entire memory to start consuming, but can be used to ensure that the dimension is the smallest possible impression of the memory when the processing is completed.
raman
OLAP Product: tm1
Post by raman »
BariAbdul wrote: Wed Sep 20, 2017 11:30 am Have you defined the path correctly in the TI :
ELSE;
ProcessQuit;
ENDIF;
so i have to create two processes for fileexists to work ,please tell if there is some way i can do in single process
and can i use a if within a if in ti
raman wrote: Wed Sep 20, 2017 10:20 am i tried this
else;
ProcessQuit;
endif;
No, it isn't sending your process into a loop as you do not have any looping code, i.e., no WHILE statement. What you cannot do is use this logic in the Data tab, it must be in the Prolog. Yes, it is technically possible to do a FileExists in the Data tab but not with the logic you are using.
raman
OLAP Product: tm1
Post by raman »
can you suggest if file is missing i have to exit the process with a message, how to do that
Version: PAL 2.0.9.18
One option is:
Above the ProcessQuit, add a line with the LogOutput function. Then you get the message you want in the message log. If you want to have the messsage in a different way, please give more context.
IBM Champion 2024
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
You could get further info regarding LogOutput here:
https://everanalytics.wordpress.com/201 ... ognos-tm1/ Thanks
