ExecuteCommand on SFTP file transfer
fleaster
Excel Version: XL2010
Post by fleaster » Tue Sep 19, 2017 8:21 am
Ok, am tearing out my hair on this one (not that I had much in the first place!) - am trying to trigger an SFTP file transfer via TI, but it does not appear to be working.
Command1 = 'cmd /c scp2 \\APAUSXXXX\TM1\TempTest\TEST_SFTP_170919-1010.txt ufbXXXX@XXXXX1012.apac.XXXXXXXX.net:/var/app/XXXXXXXXXXXX/apac/uat1/AU/ODS/TEST_SFTP_170919-1010.txt' ;
ExecuteCommand(Command1, 1);
Considerations:
1. the command line works perfectly when executed from the server in DOS
2. similarly a .bat file with this command line works perfectly on the server
3. when the same command line is executed using TI, nothing happens
4. when the same .bat file is executed using TI, nothing happens
5. tested a simple DOS copy function executed from TI, and it works fine
...what other factors should I test? any ideas what the issue could be? :)
thanks!
Matt
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Re: ExecuteCommand on SFTP file transfer
Post by AmbPin » Tue Sep 19, 2017 8:43 am
Does the account that the TM1 service is running as have all necessary permissions?
Yo could test this by right-click and run-as on your BAT file using the TM1 service account credentials.
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg » Tue Sep 19, 2017 12:46 pm
1. Run service as user with same premission
2. cmdd= 'cmd /c " YOUR COMMAND HERE "';
3. Maybe need use powershell ????
fleaster
Post by fleaster » Tue Sep 19, 2017 11:24 pm
Thanks for the responses... yes, I have run it via direct logon to the server and it works perfectly... might have a look into Powershell, otherwise am not sure what else can be tried :(
M.
Drg
OLAP Product: tm1
Post by Drg » Mon Sep 25, 2017 8:06 am
M.
Use double quotes!!!
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble » Fri Sep 29, 2017 12:51 pm
Process Monitor can be a helpful tool to diagnose what is going on as well (https://docs.microsoft.com/en-us/sysint ... ds/procmon)
