Unable to pull views in TM1 Cafe
rni
OLAP Product: IBM Cognos TM1
Post by rni » Fri Sep 08, 2017 6:58 am
When I try to pull some views from the package, It shows 'working' but then nothing appears (not even an error message). This happens only for some views and remaining are opening without any issue.
Also all the views open in TM1 web url. Only Cafe is causing trouble.
Anyone faced such a situation before?
Thanks in Advance :)
Edward Stuart
Version: All
Excel Version: All
Re: Unable to pull views in TM1 Cafe
Post by Edward Stuart » Fri Sep 08, 2017 8:02 am
What is listed in the logs?
rni
Post by rni » Fri Sep 08, 2017 10:25 am
The log file goes something like this:
# 2017/09/08 10:35:15.524
[Severity=Information]
[Exit] HideLoadingForm()
[Thread=1, Background=True, Pool=False]
[ms=0]
> Framework.AsyncCall.SendException(Object obj)
> Framework.AsyncCall.ExceptionCallback(Exception ex)
> Framework.AsyncItem`3.OnError(Exception ex)
> CognosOfficeReporting.CallWrapper`3.onError(Exception error, Tag tag)
< CognosOfficeReporting.CUILoadingForm.HideLoadingForm()
m_LoadingFormRefCounter = -1
Visible = False
# 2017/09/08 10:35:16.757
[Severity=Verbose]
[Entry] SelectNode(TreeNode node)
> CognosOfficeReporting.MultiSelectTreeView.OnMouseDown(MouseEventArgs e)
> CognosOfficeReporting.MultiSelectTreeView.SelectNode(TreeNode node)
# 2017/09/08 10:35:16.760
[Severity=Verbose]
[Entry] ToggleNode(TreeNode node, Boolean bSelectNode)
> CognosOfficeReporting.MultiSelectTreeView.ToggleNode(TreeNode node, Boolean bSelectNode)
# 2017/09/08 10:35:16.762
[Severity=Verbose]
[Exit] ToggleNode(TreeNode node, Boolean bSelectNode)
[ms=0]
< CognosOfficeReporting.MultiSelectTreeView.ToggleNode(TreeNode node, Boolean bSelectNode)
# 2017/09/08 10:35:16.764
[Severity=Verbose]
[Entry] OnBeforeSelect(TreeViewCancelEventArgs e)
> CognosOfficeReporting.MultiSelectTreeView.OnBeforeSelect(TreeViewCancelEventArgs e)
# 2017/09/08 10:35:16.767
[Severity=Verbose]
[Exit] OnBeforeSelect(TreeViewCancelEventArgs e)
[ms=0]
< CognosOfficeReporting.MultiSelectTreeView.OnBeforeSelect(TreeViewCancelEventArgs e)
# 2017/09/08 10:35:16.770
[Severity=Verbose]
[Entry] OnAfterSelect(TreeViewEventArgs e)
> CognosOfficeReporting.MultiSelectTreeView.OnAfterSelect(TreeViewEventArgs e)
# 2017/09/08 10:35:16.773
[Severity=Verbose]
[Exit] OnAfterSelect(TreeViewEventArgs e)
[ms=0]
< CognosOfficeReporting.MultiSelectTreeView.OnAfterSelect(TreeViewEventArgs e)
# 2017/09/08 10:35:16.777
[Severity=Verbose]
[Exit] SelectNode(TreeNode node)
[ms=17]
< CognosOfficeReporting.MultiSelectTreeView.SelectNode(TreeNode node)
# 2017/09/08 10:35:18.070
[Entry] ShowLoadingForm(Boolean allowCancel)
> CognosOfficeReporting.ApplicationView.CUIManager_MouseUp(Object sender, MouseEventArgs e)
> CognosOfficeReporting.ApplicationPresenter.View_DragEnd(Object sender, MouseEventArgs e)
> CognosOfficeReporting.UIManager.DragEnd(Object sender, MouseEventArgs e)
> CognosOfficeReporting.MapUI.DragEnd(ScreenMouseEventArgs e)
> CognosOfficeReporting.LoadingForms.CallWithRetry(In args, DoWork`2<Out,In> method, OnComplete`2<Out,Tag> complete, OnError`1<Tag> error, RetryTest retry, Tag tag, MethodInvoker onCancel)
> CognosOfficeReporting.CUILoadingForm.CallWithRetry(In args, DoWork`2<Out,In> method, OnComplete`2<Out,Tag> complete, OnError`1<Tag> error, RetryTest retry, Tag tag, MethodInvoker onCancel)
> CognosOfficeReporting.CallWrapper`3..ctor(CUILoadingForm form, In args, DoWork`2<Out,In> method, OnComplete`2<Out,Tag> complete, OnError`1<Tag> error, RetryTest retry, Tag tag, MethodInvoker cancel)
> CognosOfficeReporting.CUILoadingForm.ShowLoadingForm(Boolean allowCancel)
# 2017/09/08 10:35:18.080
[Exit] ShowLoadingForm(Boolean allowCancel)
[ms=8]
< CognosOfficeReporting.CUILoadingForm.ShowLoadingForm(Boolean allowCancel)
m_LoadingFormRefCounter = 1
# 2017/09/08 10:35:18.234
[Entry] HideLoadingForm()
> Framework.AsyncCall.SendComplete(Object ignored)
> Framework.AsyncCall.CompleteCallback()
> Framework.AsyncItem`3.OnComplete()
> CognosOfficeReporting.CallWrapper`3.onComplete(Out result, Tag tag)
# 2017/09/08 10:35:18.243
[ms=3]
m_LoadingFormRefCounter = 0
Visible = False
# 2017/09/08 10:35:18.248
> CognosOfficeReporting.MapUI.GetTreeNodeData_Complete(Object dragData, SheetCoordinate sc)
> CognosOfficeReporting.WorkbookMapper.DropView(CDLAnalysis report, SheetCoordinate sc)
# 2017/09/08 10:35:18.258
[ms=7]
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg » Wed Sep 13, 2017 7:55 am
maybe you data in vie so big and you need config CAFE for this dataset?
try change params in cafe ->IBM cognos -> parapmetars -> ibm cognos analysis
rni
Post by rni » Wed Sep 13, 2017 8:33 am
Thanks for your suggestions. Looks like we had a compatibility issue. TM1 was upgraded to Fix Pack 7, but Cafe was still in Fix Pack 4. :P
