Excel Calc Options overwritten at TM1Web
Posted: Tue Sep 05, 2017 3:06 pm
by rafaewolie
I changed the TM1web_Config.xml parameter UseBookRecalcSetting to true to use Excel's calculation option control.
When I Publish the perspectives that is set to Automatic calculation to an application in TM1web it seems that the AutoRecalc option is changed and the file starts to behave as a manually calculated workbook.
The other recalc parms are:
<add value="true" key="RecalcOnActivate"/>
<add value="True" key="RecalcOnDataValidationChange"/>
<add value="True" key="RecalcOnPicklistChange"/>
Am I missing something?
Tks.
