Rule
st2000
OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
Version: 10.2.0 FP3
Excel Version: Excel 2013
Rule
Post by st2000 »
Hope somebody could throw a light on my misunderstanding:
I try to implement a spreading procedure and first of all I want to have an indicator for changes at all (by rule).
I attached a picture showing the cube, the attributes cube assigned to the main cube and the rule:
['Changed',{'A','B'},'Expenses'] = IF (DB('Value',ATTRS('Status', !Status, 'Deltaelement'),'Expenses') = 0 , 1, 2);
The attribute is correctly resolved as 'A_Delta' resp. 'B_Delta', and I can save the rule and refresh the cube viewer without errors.
But the cell Valuetype=Value,Status=A_Delta,acc2=Expenses contains '200', which is != 0, so I'd expect the rule to get a result of '2' here, where ValueType=Changed, which should be the indicator to process the A_Delta afterwards.
I fear it is a very 'dummy' question, but I didn't find something similar in the historic posts...
(The xy_Delta-cells are intended to take input in a websheet, later these inputs should be spreaded via TI instead of immediately via contextmenu spreading methods.)
Misunderstanding of the correct FEEDER, maybe?
Stefan
Re: Rule
st2000 wrote: Tue Sep 05, 2017 11:59 am
Check your syntax on this rule. The proper syntax when using DB to reference a cube is:
DB('Name of Cube', Dim1, Dim2, Dim3....Dimx)
st2000
Version: 10.2.0 FP3
Re: Rule
Post by st2000 »
Aaarghh, indeed it WAS a dummy question, just oversaw the missing cubename in DB-formula while thinking around potential errors in ATTRS.
Sorry for polluting the forum and thanks for the hint... :oops:
Stefan
Re: Rule
tomok wrote: Check your syntax on this rule. The proper syntax when using DB to reference a cube is:
Yes. Although it would be a pretty decent enhancement if you could use a blank string as the first argument in a DB() to mean "Me. The cube that I'm in" the same way that it works for the ConsolidatedAvg/Min/Max/Count functions.
It would make generic rules that much more portable.
I'm not holding my breath.
