Transfer data in the cube to a specific cell
Wirt
Excel Version: 10
Post by Wirt » Mon Sep 04, 2017 6:15 am
Hello everybody!
I have a question about copying data from one element to another element in one cube using TI. I have a source, and a dim period, I need to copy data from one period to any other. It is necessary that when process start, I could choose the period in which to copy the data. how is this possible? Thank you!
BariAbdul
OLAP Product: TM1,Cognos
Version: 9.5.2
Re: Transfer data in the cube to a specific cell
Post by BariAbdul » Mon Sep 04, 2017 7:12 am
Wirt
Excel Version: 10
Post by Wirt » Mon Sep 04, 2017 7:53 am
thanks for the info
but I do not quite understand what is meant MY_DIMENSION_VARIABLES_CHANGE_OVER_HERE and OTHER_DIMENSION_VARIABLES
(I'm sorry, I'm not completely versed in the processes)
IF(CELLISUPDATEABLE(vCubeName,
MY_DIMENSION_VARIABLES_CHANGE_OVER_HERE,
pTargetElement,OTHER_DIMENSION_VARIABLES)=1);
IF(VALUE_IS_STRING=0);
CELLPUTN(NValue,vCubeName,
pTargetElement,OTHER_DIMENSION_VARIABLES);
ELSE;
CELLPUTS(SValue,vCubeName,
ENDIF;
ENDIF;
Version: PAL 2.0
Post by Wim Gielis » Mon Sep 04, 2017 9:03 am
Hello Wirt,
It means that you need to supply the correct arguments to the functions CellIsUpdateable, CellPutN, CellPutS, ...
This depends on your cube structure and it's only that can do this because you know the cube structure, the variables, and so on.
http://www.wimgielis.com ==> 104 TM1 articles and a lot of custom code
Newest blog article: Delete a cube and its dimensions
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg » Wed Sep 13, 2017 8:10 am
