ASCIIOUTPUT to csv to show data in different columns
- Version: TM1 Perspectives 10
- Excel Version: Excel 2016
Hi everyone,
I am trying to use below code to export some data into csv file. When working with the TM1 cube things are fine but when working with external .txt file it is not working ok. It show results as for example like this
Ashleigh|Final|201709 but i want it in different column in csv and not single text string.
ASCIIOUTPUT(fileName,'Debug', UserName,Version,Period);
please help.
thank you
please help.
thank you
- Version: PAL 2.0.9.18
Re: ASCIIOUTPUT to csv to show data in different columns
I am guessing that the text file settings (like the delimiter for columns) that you use for importing the txt file, still apply when exporting the data. Is this the case maybe ?
IBM Champion 2024
IBM Champion 2024
That's correct Wim. Is there a way to change the delimiter for export?
Well you are stuck my friend as TM1 only provides the local variables DatasourceASCIIDelimiter & DatasourceASCIIQuoteCharacter which apply to BOTH the text file being read AND the text file(s) being exported. You would think it would be sensible to have separate variables but fact is we don't.Ashleigh W wrote: ↑Wed Aug 30, 2017 1:13 pm That's correct Wim. Is there a way to change the delimiter for export?
So the only thing you can do is to work around it by exporting (from the TI's POV) a single field but splice into this your real delimiter. Expand will be your friend here. To get a good working result with this you will have to have input and export data that doesn't need a quote character.
###PROLOG
DatasourceASCIIDelimiter = '|';
DatasourceASCIIQuoteCharacter = '';
sDelim = ';'
###DATA
sTextOut = Expand( '%V1%%sDelim%%V2%%sDelim%%V3%%sDelim%%V4%%sDelim%%V5%%sDelim%' );
AsciiOutput( sFileOut, sTextOut );
Correct, either you use Expand like Lotsaram shows you, either you use the concatenation operator ( | ) to string the data together.
Make sure that your numeric values are exported correctly too, if applicable.
IBM Champion 2024
IBM Champion 2024
- gtonkin
Have not had the time to test it but would TextOutput also apply the DatasourceASCIIDelimiter & DatasourceASCIIQuoteCharacter or do comma delimited?
I did a quick test George and TEXTOUTPUT seems to use the datasourceasciidelimiter.
IBM Champion 2024
IBM Champion 2024
That's actually a hidden benefit of Expand all variables are treated as string even the numerics. If you're not fussy about number formatting then no need to do the additional type conversion.Wim Gielis wrote: ↑Wed Aug 30, 2017 2:50 pm Correct, either you use Expand like Lotsaram shows you, either you use the concatenation operator ( | ) to string the data together.
- gtonkin
Thanks Wim-noted.Wim Gielis wrote: ↑Wed Aug 30, 2017 4:16 pm I did a quick test George and TEXTOUTPUT seems to use the datasourceasciidelimiter.
lotsaram, your example works for me. I also tried to place DatasourceASCIIQuoteCharacter=','; at the bottom of Prolog and it seems to export in comma Delimiter in csv but betweeb every field there is |.
thanks for your help. this should keep me going.
Say again please ?Ashleigh W wrote: ↑Thu Aug 31, 2017 6:30 amit seems to export in comma Delimiter in csv but betweeb every field there is |.
What is it, a comma or a pipe symbol ?
IBM Champion 2024
IBM Champion 2024
In fact, this is not correct.lotsaram wrote: ↑Wed Aug 30, 2017 1:30 pm Well you are stuck my friend as TM1 only provides the local variables DatasourceASCIIDelimiter & DatasourceASCIIQuoteCharacter which apply to BOTH the text file being read AND the text file(s) being exported. You would think it would be sensible to have separate variables but fact is we don't.
You can use the local variable DatasourceASCIIDelimiter in the Prolog tab, and again in the Data tab, for instance. It will work.
IBM Champion 2024
IBM Champion 2024
there is a pipe '|' between each field. so in csv when opened in excel it looks like thisWim Gielis wrote: ↑Thu Aug 31, 2017 7:45 amSay again please ?Ashleigh W wrote: ↑Thu Aug 31, 2017 6:30 amit seems to export in comma Delimiter in csv but betweeb every field there is |.
all these words in different cells -- >> blank | Ashleigh | Final | 201709
Interesting, I guess you never know until you try!Wim Gielis wrote: ↑Thu Aug 31, 2017 7:51 amIn fact, this is not correct.lotsaram wrote: ↑Wed Aug 30, 2017 1:30 pm Well you are stuck my friend as TM1 only provides the local variables DatasourceASCIIDelimiter & DatasourceASCIIQuoteCharacter which apply to BOTH the text file being read AND the text file(s) being exported. You would think it would be sensible to have separate variables but fact is we don't.
That's what I did
IBM Champion 2024
IBM Champion 2024
