Hi.. i want to transfer value from one cube to another cube using TI
but there is some value from source cube that came from rule calculated... How i transfer that value using TI ?
I already tried to uncheck skip rules calculated... but it didn't work... is there another way ? thank you
Transfer rule value to other cube using TI
- jim wood
- Version: PA 2.0.7
Re: Transfer rule value to other cube using TI
That should work. Without more details it's difficult to give an exact answer but it does sound like the values are not fed,
Jim.
Jim.
Drg
- OLAP Product: tm1
- Version: 10.2.0 - 10.3.0
show your TI code!
st2000
- OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
- Version: 10.2.0 FP3
- Excel Version: Excel 2013
I had a (maybe) similar issue, and could solve it. My view (TI's sourceview) shows interactively also C-elements, but the TI does only log out N-element's values.
Before, I tweaked the view using the data source selectors GUI, and there I checked on to skip the consolidations. In the TI-view generated later and made to source by these commands...:
...I expected to catch via TI/data tab the same amount of cells like the same view in the cube viewer does. But I never got the C-elements as displayed in the viewer grid.
It was only a desperate try&error-idea to add: which switches off the skipping (as per doc this is intended to use for writing out .cma-files). Now it works as desired and initially expected. It seems that this switch was in effect all the time. And not kept at 0 always when the view was created new per TI execution. Unfortunately I didn't found a TI variable to derive the current status of a view about skipping C/rule-values/zeros.
If this happens to you, under the hood, concerning rule-values this might help: Set the Flag=0 and try again. If the cause was a suppression of rule values, your TI should be able the catch them again. Hope it helps.
DatasourceNameForServer=sCube2Spread;
DataSourceType='View';
DatasourceCubeview=sViewName;It was only a desperate try&error-idea to add:
ViewExtractSkipCalcsSet (sCube2Spread, sViewName,0);If this happens to you, under the hood, concerning rule-values this might help:
ViewExtractSkipRuleValuesSet (Cube, ViewName, Flag);-----------------------------------
Stefan
Stefan
