New in TM1, i would like to create a process to copy data between scenarios within the same cube
If the scenario is "Forecast", the TI will copy the last "Actual" Data & paste it for next coming month. For example if the "Actual"month is July, the process will copy/paste the same data of July in August, Sept...December
When i run the TI below, the error "the subset "vSubName" not fount in dimension "t_scenario". !!!!!!
here is my prolog & data tab
###prolog###Prolog#####
### Constants ###
cProcess = GetProcessName();
cUser = TM1User();
cTimeStamp = TimSt( Now, '\Y\m\d-\hh\im\s' );
sRandomInt = NumberToString( INT( RAND( ) * 100000 ));
cDebugFile = GetProcessErrorFileDirectory | cProcess | '.' | cTimeStamp | '.' | sRandomInt ;
nErrors = 0;
nHeader = 1;
cSubset = '}' | cProcess;
### Initialise Debug ###
If( pDebug >= 1 );
# Set debug file name
sDebugFile = cDebugFile | 'Prolog.debug';
# Log start time
AsciiOutput( sDebugFile, 'Process Started: ' | TimSt( Now, '\d-\m-\Y @\h:\i:\s' ) );
# Log parameters
AsciiOutput( sDebugFile, 'Parameters: plannification : ' | pCyclePlannification );
EndIf;
### Get Planning cycle for SYS_Time
IF ( pCyclePlannification @= 'Budget');
cCycle = 'Budgeting';
ELSEIF ( pCyclePlannification @= 'Forecast');
cCycle = 'Forecasting';
ELSE;
ProcessQuit;
ENDIF;
cDestScenario = CellGetS ('SYS_Time', cCycle, 'Scenario' );
### Cube information ###
pCube = 'Exchange_Rate ';
vDimName1 = 'Currency';
vDimName2 = 't_Months';
vDimName3 = 't_Scenario';
vDimName4 = 'm_Index';
vTemp = '}VZO_' | cProcess | cTimeStamp | sRandomInt;
vViewName = vTemp;
vSubName = vTemp;
#View
ViewCreate(pCube, vViewName);
##Subsets
SubsetCreate ( vDimName1 , vSubName);
SubsetCreate ( vDimName3 , vSubName);
SubsetCreate ( vDimName4 , vSubName);
##Subsets Elements
SubsetElementInsert ( vDimName1 , vSubName ,'USD-CAD' , 1);
SubsetElementInsert ( vDimName1 , vSubName ,'USD-CNY' , 2);
SubsetElementInsert ( vDimName3 , vSubName , cDestScenario, 1);
SubsetElementInsert ( vDimName4 , vSubName ,'Period Average' , 1);
#Assignation
ViewSubsetAssign( pCube, vViewName, vDimName1, vSubName);
ViewSubsetAssign( pCube, vViewName, vDimName2, 'SYS_allmonth');
ViewSubsetAssign( pCube, vViewName, vDimName3, 'vSubName');
ViewSubsetAssign( pCube, vViewName, vDimName4, 'vSubName');
ViewZeroOut(pCube, vViewName);
##suppression de la vue et des subsets
ViewDestroy(pCube, vViewName);
SubsetDestroy(vDimName1, vSubName);
SubsetDestroy(vDimName3, vSubName);
SubsetDestroy(vDimName4, vSubName);
OldCubeLogChanges = CUBEGETLOGCHANGES(pCube);
CUBESETLOGCHANGES(pCube, 0);
[/td]
####Data####
[td]Data###
If( pDebug >= 1 );
sDebugFile = cDebugFile | 'Data.debug';
# Log start time
IF (nHeader = 0);
nHeader = 1;
ENDIF;
EndIf;
IF (pDebug = 2);
ItemSkip;
ENDIF;
cMyMonth=CellGetS('SYS_Time', 'Actuals', 'Month');
cPeriodAverage=CellGetN('Exchange_Rate',Currency,'cMyMonth',CellGetS('SYS_Time', 'Actuals', 'Scenario'),'Period Average');
iF( pCyclePlannification@='Forecast' & 't_Month'@>cMyMonth);
CellIncrementN(cPeriodAverage, 'Exchange_Rate',Currency, t_months,'cDestScenario','Period Average');
ENDIF;
