Pmhub Configuration
Posted: Sat Aug 12, 2017 3:54 pm
by mce
I need help regarding a pmhub/pm/admin issue. It is Planning Analytics Local version 2.0.
When I was configuring OPS Console using http://localhost:9510/pmhub/pm/admin address, I somehow did a mis-configuration and I also set the admin group, now I am not able to change any configuration via web URL of http://localhost:9510/pmhub/pm/admin. It keeps sayinh "Un-authorized request. Please login.". I somehow need to change the configuration back so that I can update those pmhub/admin configuration.
Do you know where these pmhub configuratioons are stored in file system? Which file I need to change to fix the configuration issue?
Many thanks in advance.
Re: Pmhub Configuration
Posted: Tue Aug 15, 2017 9:15 am
by kangkc
The configuration should be in fpmsvc_config.xml file in the \webapps\pmpsvc\WEB-INF\configuration\ folder, or at least in 10.2.x.
Posted: Tue Aug 15, 2017 11:32 am
by mce
No, fpmsvc_config.xml file stores changes in pmpsvc admin configuration, not the one in pmhub admin configuration.
Posted: Tue Aug 15, 2017 1:54 pm
by mce
I found some of those pmhub/pm/admin parameters are stored in different *.config files under folder C:\Program Files\ibm\cognos\tm1_64\wlp\usr\shared\config\pmhub_configurations\com\ibm\ba\pm\resource .
