Manage Rights error Cognos Planning Analytics V2.0.X
Ana Ventura
OLAP Product: SSAS, TM1
Version: 10 2 2
Post by Ana Ventura » Tue Aug 01, 2017 10:57 am
I have a problem with manage rights from my TM1 Web Applications. When i tried to save my rights i had an error "An error occurred while creating Cognos objects".
I added the Clients and Groups from Cognos BI in Architect and after i tried to save my rights i received this error.
I saw the logs from TM1server.log (on attachement) i have some errors:
8960 [28] ERROR 2017-08-01 09:42:36.488 TM1.Mdx.Interface Syntax error at or near: '[}ElementCaptionsByDimension] WHERE([}Di ... ', character position 88
8960 [28] ERROR 2017-08-01 09:42:36.492 TM1.Mdx.Interface Syntax error at or near: '[}ElementCaptionsByDimension] WHERE([}Di ... ', character position 88
8960 [28] INFO 2017-08-01 09:42:36.560 TM1.Process Process "}tp_modify_application_attribute" executed by user "AD/Ana Ventura"
8960 [28] INFO 2017-08-01 09:42:36.562 TM1.Process Process "}tp_modify_application_attribute": finished executing normally, elapsed time 0.00 seconds
8960 [28] INFO 2017-08-01 09:42:36.662 TM1.Process Process "}tp_job_end" executed by user "AD/Ana Ventura"
8960 [28] INFO 2017-08-01 09:42:36.664 TM1.Process Process "}tp_job_end": finished executing normally, elapsed time 0.00 seconds
8960 [28] INFO 2017-08-01 09:42:36.766 TM1.Process Process "}tp_set_running_maintenance" executed by user "AD/Ana Ventura"
8960 [28] INFO 2017-08-01 09:42:36.768 TM1.Process Process "}tp_set_running_maintenance": finished executing normally, elapsed time 0.00 seconds
I saw that the prefix from Table Select Group in TM1 Web Applications show the group different way, it has a slash and not the backslash (Cognos/<group>). I spouse that the bar it is important for this process. (i send you the image in attachment)
How can i solve this problem?
Thank you,
Ana Ventura
Admin Note: Please do NOT post into the Enhancements Forum unless you are asking for an enhancement as defined here. This post has been moved.
