TM1 Object dependency walker- get list of all dependent objects
Posted: Fri Jul 14, 2017 1:38 am
Hi Guys,
Is there a free tool available to get a list of dependencies ( i.e. TM1 objects ) that are dependent on what are you targeting?
For example target cube A , has dependent dimensions A, B, C and D, and also has a Rule file
This rule file also points to other cubes etc. I would like to grab these objects as well + other associated processes.
What I want to be able to do is pass in the name of cube for example then call this script and punch out a file with
a list of dependent objects and then call 7zip to target this file and zip up the objects.
Any ideas?
Zark
Any ideas?
Zark
