Direct edit dimension collection has not been cleared before commit
Post by lotsaram » Thu Jun 22, 2017 2:23 pm
Has anyone ever seen the following ERROR status log message in the tm1server.log and know what it means?
ERROR TM1.Commit Direct edit dimension collection has not been cleared before commit.
qml
Version: 2.0.4 and all previous
Excel Version: 2007 - 2016
Re: Direct edit dimension collection has not been cleared before commit
Post by qml » Tue Jul 04, 2017 2:28 pm
What version did you see it in?
I have started seeing this message after upgrading our on-premise 10.2.2 from build 10.2.20300.98 to build 10.2.20700.43. It happens at the end of any process that makes use of the Direct metadata functions, but seems to have no impact on the completion status of the process or its outcomes. However, I have seen it coincide with a rollback/restart of a process on one occasion - but I don't have enough evidence to conclude that it was caused by this error.
In any case this looks like a defect to me.
Kamil Arendt
Post by lotsaram » Tue Jul 04, 2017 5:26 pm
Thanks for the response. This is on 10.2.2 FP7 and we didn't see it on FP5 which was the previous version on this site.
Got a somewhat dubious response from support which didn't clarify at all whether this is an actual error or overenthusiastic logging.
Although there is is odd (very rare) use of DimensionElementInsertDirect in the system with the error the odder thing is that this error crops up at random after commits of dimensions and not always necessarily the ones where TI is using the direct update functions.
Gabor
Version: [2.x ...] 11.4.x / PAL 2.0.6
Excel Version: Excel 2010-2013
Post by Gabor » Wed Jul 12, 2017 11:38 am
I've seen that error after moving to 10.2.2 FP7, but could get rid of the message by adding "DimensionUpdateDirect(DimName)" at the end of the Epilog of each process handling with direct dim updates.
qml
Post by qml » Thu Jul 13, 2017 9:37 am
Gabor wrote:I've seen that error after moving to 10.2.2 FP7, but could get rid of the message by adding "DimensionUpdateDirect(DimName)" at the end of the Epilog of each process handling with direct dim updates.
Weird. I always do the DImensionUpdateDirect in Epilog after any Direct inserts, mostly because without that rules don't get attached to elements added in that way (one to look out for). Despite that I still see the same error as Lotsa.
Kamil Arendt
Post by lotsaram » Thu Jul 13, 2017 2:22 pm
From own testing and confirmed from IBM support adding DimensionUpdateDirect to the Epilog does not make this error message go away.
What I still don't know is whether the error actually is an "error" or just something g that should be ignored.
Post by lotsaram » Tue Oct 17, 2017 5:18 pm
By way of update support opened a collab with development on this error and it seems that IBM development believe the error message is caused by an empty subset or UDC at the time the dimension is updated. Thus can be filed into the category of "not really an error".
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent » Mon Aug 06, 2018 9:18 am
Except that if you happen to be rebuilding a dimension then the 1st element to be added causes this error, and subsequent tasks on the dim fail. I'm currently getting errors on adding attribute values because of this; TM1 doesn't think my elements have been added, and on completion the dim is missing them.
Production: TM1 64 bit 10.2.2, Windows 2008/2012 Server. Excel 2010, IE11 for t'internet
