Error accessing set editor from PAx
Posted: Wed Jun 14, 2017 1:47 pm
by Paul Segal
Anyone else come across this? Everything else seems to be working OK. This is accessing GO_New_Stores, so should be fairly standard.
- Capture2.PNG (44.09 KiB) Viewed 4284 times
Re: Error accessing set editor from PAx
Posted: Wed Jun 14, 2017 1:53 pm
by Steve Rowe
The pre-requisite that is often missed is that IE11 is required on pax machines, this looks like that error.
Posted: Wed Jun 14, 2017 2:19 pm
by Paul Segal
It doesn't look like that's it - IE11 is installed, and I've even made it default now. I still get the same result.
Posted: Wed Jun 14, 2017 4:16 pm
by Steve Rowe
Did you point PAx at PAW, rather than the TM1 Service? That is the other area that generates an error when getting into the common objects. I don't think that is it since I think that is a simple 404 error.
Posted: Wed Jun 14, 2017 4:21 pm
by Paul Segal
I did (I'm pretty sure). I get the PAW-like logon screen, which works and lets me in.
Posted: Thu Jun 15, 2017 2:19 pm
by Paul Segal
Well, I've fixed it, but not cured it. I had the http port set to 8080 on the PAW start.bat rather than 80 as there was something else on 80. I've got rid of the something else and rebuilt PAW using port 80 and it now works. Thanks for the help though, Steve.
