TM1 Scan Function
macklovesraine11
OLAP Product: IBM Cognos TM1
TM1 Scan Function
Post by macklovesraine11 »
Hello Guys,
Good day.
I'd like to know how can I extract sub-strings from a string. Please see the following example:
PEPSI-MS-0870-3/PO:4500752654.30|NSW|SS
I would want to extract the 'NSW' and 'SS' from that string and store them in separate variables. How can I possibly do this in TM1? My senior said that I do a scan of the pipe.
Thanks in advance! :)
EvgenyT
Version: PAL 2.0.8
Re: TM1 Scan Function
Post by EvgenyT »
macklovesraine11 wrote:Hello Guys,
Good day.
Are you able to provide an example you attempting to use SCAN function?
macklovesraine11
Sorry I haven't tried out yet.
macklovesraine11 wrote:Sorry I haven't tried out yet.
Have you at least read the documentation on the Scan and SubSt functions yet?
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
Do you want to extract NSW and SS from the string or do you want to dynamically extract the string after the first pipe and the string after the second pipe?
if you want to store NSW and SS in a variable then just say v1 = 'NSW' and v2 = 'SS'!
Of course I know this isn't what you want to do but it could be read in that way!
Assuming you want to find the string after the pipes and assuming the full string always includes 2 pipes and the string you want to extract always comes after the pipes and the string you want to extract after the first pipe is always 3 characters long and 2 characters long after the second pipe then something like:
vScan = subst('PEPSI-MS-0870-3/PO:4500752654.30|NSW|SS', scan('|', 'PEPSI-MS-0870-3/PO:4500752654.30|NSW|SS') + 1,long('PEPSI-MS-0870-3/PO:4500752654.30|NSW|SS'));
vScanNSW = subst(vScan,1,3);
vScanSS = Subst(vScan,5,2);
may suffice.
But more information would mean less assumptions on my part!
cheers, mark
macklovesraine11
Mark RMBC wrote:Do you want to extract NSW and SS from the string or do you want to dynamically extract the string after the first pipe and the string after the second pipe?
may suffice.
cheers, mark
Hi Mark,
Thanks for the input. I would want to dynamically extract sting after the first pipe and the string after the second pipe. Number of characters is not always 3 and 2, sometimes it can be 2 and 4, 3 and 3, 2 and 2. Something like that.
Thanks, hope this info helps :)
Michael
Hi Michael,
Consider the functions Scan, Subst, Long.
That should do it.
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
You haven't said where this string data comes from.
If it were to come as a text data source you might be able to set the delimiter to the pipe char which would split it automatically for you.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Well then you could add into the code above:
vScanA = Scan('|', vScan);
and change the following:
vScanNSW = subst(vScan,1,vScanA-1);
vScanSS = Subst(vScan,vScanA+1,long(vScan));
Assuming all the assumptions are valid!
macklovesraine11
Hi Guys,
Good day.
Thanks for all your inputs! I gained the idea based on your suggestions, it now gives the desired result and output looks good.
Thanks everyone!
Michael
Hi, thank you for the feedback, glad it's solved !
