Display Alias in Members drop down for PAW and PAX
BigG
OLAP Product: IBMPA
Version: PA 2.0 Cloud
Post by BigG »
hi, with the Task Pane in PAX and PAW you can drill down on a dimension Sets, levels and members
Does anyone know how to use an Alias as a default for this function, standard behaviour is to display the element name(code)?
GG
dr.nybble
Excel Version: Excel 2007
Re: Display Alias in Members drop down for PAW and PAX
Post by dr.nybble »
Are you talking about the content tree? If so by default it will display the caption alias (which falls back to invariant name if not defined). There is currently no way to configure it to use another alias. You could create a rule on the attributes cube so your alias can be displayed via the Caption attribute.
BigG
OLAP Product: IBMPA
Post by BigG »
think content tree may be something different it is the task pane
IBM are on to it with no fix date
https://www.ibm.com/developerworks/rfe/ ... _ID=102200
GG
dr.nybble
Post by dr.nybble »
OK I see the tree is called "Task Pane" in PAX. In PAW we refer to it as the "Content Tree".
TM1 now supports localized aliases on many objects including cubes, dimensions, hierarchies, views, sets, TI processes......
Best practice is to use the localized Caption alias as PAW will automatically use that.
BigG
OLAP Product: IBMPA
Post by BigG »
great - using caption alias works, thanks for this
But, you cannot select element names in the set editor eg. 'No Alias' displays the caption
GG
