CAFE VBA/VBS automation - cannot log in to TM1 server
Posted: Fri Jun 02, 2017 12:12 pm
by daniel.havassy
Hi Everyone,
I'd like to ask for some help regarding a CAFE VB automation issue.
What I'm trying to accomplish: After a data load, automatically refresh a CAFE Excel worksheet (it has two FlexViews) which I use for a post-load data quality check. I'd like to achieve this by executing a VB script file from the TI Epilog.
Issue: Logging in to the TM1 server from the script doesn't work, and so no further function is executed properly, although the Logon function returns True.
Further details: TM1 and CAFE 10.2.2. I have set up the CAFE automation using the samples in the CAFE installation directory's Automation folder.
Check below the relevant part of the code that I use. Any help is much appreciated.
Set objWB = objExcel.Workbooks.Open("C:\some path\someFile.xlsm")
objWB.Activate
bSuccess = objExcel.Run("Logon", "http://server/ibmcognos/cgi-bin/cognos.cgi", "user", "pwd", "namespace")
If (bSuccess) Then
    objExcel.Run "ClearAllData"
    objExcel.Run "RefreshAllData"
    objExcel.Run "Logoff"
    objWB.Save
End If
