TM1Top for Planning Analytics Local 2.0
mce
Excel Version: 2013 2016
Post by mce »
Is it possible to use TM1Top with Planning Analytics Local 2.0 ?
Not officially, but practically...
We have been using it in version 10.2.2. But the same DLLs did not work for new version. Replacing the same DLLs with the new ones coming with the new version also did not help. Is there anyone who managed to get TM1Top work with the new TM1 version?
Thanks in advance for all responses.
japwah
Version: 10.3
Re: TM1Top for Planning Analytics Local 2.0
Post by japwah »
You can use ops console instead of TM1Top
BrianL
Version: 9.5.2 10.1 10.2 PA2
Post by BrianL »
TM1Top should still work. Is it not part of the server install?
If you try to use a 10.2.2 version of tm1top, I believe there are (at least) new SSL certificates required.
ndivine
Version: Latest
Post by ndivine »
Yes, I'm using it in a couple of different PAL environments. It's officially included with the install and should only need to be configured. It is also covered in the PAL Ops Guide.
mce
Post by mce »
We managed to get it running. Thanks for all comments.
