Can Active Forms that use same title dimensions be in diffrent sheets
Posted: Wed May 03, 2017 11:54 pm
Continuing with my search for the solution on my previous post http://www.tm1forum.com/viewtopic.php?f=3&t=13250. I tried to put a few active form reports in different worksheets and put the title dimensions they share in a new worksheet call "coversheet". I was hoping by doing that, I can use the print report function to generate a set of management reports that iterate through the cost centres in a defined subset.
But I came across these problem:
t first, I moved the title dimensions (selectable with SUBNM function) over to the new worksheets and the reports didnt work. I found this posthttp://www.tm1forum.com/viewtopic.php?t=10108 in the forum where says:"The Element (2nd parameter) MUST reference a cell located on the same worksheet page as the TM1RptTitle function itself", so I move the tm1rptview formula to the "coversheet" tab as well. But it still didn't work.
What should I do? do all active forms need to be put in one sheet? Has anyone tried to achieve these without any macro? If macro is needed, can you please provide some guidance?
Gaby
Gaby
