Fix Pack Releases: PA2 / V11 Series
Version: 9.5.2 64 bit moving to 10.2.2
Post by Alan Kirk » Sun Mar 19, 2017 6:48 pm
As we've done with other versions, this post will be a repository for links to fix packs for Planning Analytics Local (PAL) 2.0 / Server Version 11. Posts will be made when a release is done but they'll be consolidated in this one.
PAL 2.0.1 Refresh 1 and PAL 2.0.1 Refresh 1 Interim Fix 1 (24 Feb 2017)
Release Announcement.
Fix List.
  • (Refresh1): Formulas giving #VALEU in certain cases.
  • (Refresh1): Copying from Excel to CAFE Subset editor not working in some cases,
  • (Refresh1): CAFE: Flex View not refreshing.
  • (IF1) Server crash caused by internal floating point rounding error during MDX axis calculation
PAL Interim Fix 16 (17 Mar 17)
Fix List.
  • Error in cell widget
  • Error Banners are stacked and require multiple clicks to clear
PAL 2.02 (04 Jun 17)
Fix List.
PAL 2.02 IF4 and higher(21 Sep 17)
Cannot be downgraded to an earlier version. See this post.
PAL 2.0.3 (19 Sep 17)
What's New Page.
PAL 2.04 (16 Feb 2018)
What's New Page
PAL 2.05 (25 Jun 2018)
What's New Page
Re: Fix Pack Releases: PA2 / V11 Series
Post by Alan Kirk » Sat Jun 03, 2017 11:50 pm
Version 2.02 has now been released; see the main post for the links. This will be stickied for 30 days.
Post by Alan Kirk » Wed Sep 20, 2017 6:40 pm
IMPORTANT: There has been a change in the data structure in PA 2.0.2 IF4. The effect is that if you apply that interim fix or higher you can no longer downgrade to an earlier version. Details can be found here.
aph1985
Version: PA 2.0.2
Post by aph1985 » Wed Sep 27, 2017 1:22 am
I just saw that PA 2.0.3 has been released. Anyone know where to download it from?
https://www.ibm.com/support/knowledgece ... 2_0_3.html
A
Post by Alan Kirk » Wed Sep 27, 2017 1:52 am
A
They may have published the release notes but that doesn't necessarily mean that they've released it yet; there was nothing in this morning's notifications e-mail about it. If they've put the notes up then the download probably isn't far behind but my blood pressure is not up to trying to find where they've hidden the download pages this week. Honestly, has anyone ever seen a more useless site than the Passport Advantage one?
Blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah-blah. A thousand million useless words about what Passport Advantage offers, and not a single link to anything even remotely useful among them. I'll come back to it when I have half a day to waste.
aph1985
Version: PA 2.0.2
Post by aph1985 » Thu Sep 28, 2017 12:50 am
It's available for download now.
mcamargo
Post by mcamargo » Fri Nov 17, 2017 5:38 pm
v2.0.3 has some problems with TM1 Applications, I have tested it on two servers and it crashes and do strange things on both, I was on 2.0.1 and now I can't downgrade to that version, I will install 2.0.2 IF4 to see if that works, but for now I strongly recommend you to beware of 2.0.3.
Version: 10.2.2., PAW
Post by Steve Rowe » Fri Jan 12, 2018 10:39 am
Hi mcamargo,
Could you elaborate on the crash and strange things please? It would be good to know some details of the use case so that we can determine if we are likely to be impacted.
Many thanks,
Steve
Post by Alan Kirk » Wed Feb 21, 2018 2:45 am
There has been a new release; 2.0.4.
This is the end of the line for the 32 bit server. It will cease to be in the 2.0.5 release. (Actually I'm surprised that it has lasted this long. I don't imagine that trying to run PAX or PAW from a 32 bit box would be a pleasant experience.)
There will also be no 32 bit installer for the classic clients (Perspectives / Architect), but the way I read it they can still be installed from the 64 bit main installer.
Post by Alan Kirk » Wed Aug 29, 2018 10:30 pm
George Tonkin brought to my attention the fact that I hadn't updated this for the release of PA 2.0.5. I thought I had, but clearly not. Thanks, George.
The Release notes can be found here.
The various headings for the What's New information can be found here.
